> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/butterfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/butterfly-primer/components/00_create/create_case_from_folder.md).
# Create\_Case\_from\_Folder
![](https://3867130239-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-LPHXQ1CBjfLUuUW94tN%2F-LPHXSV32c4bM8DFZc3w%2F-LPHX_VMsGrVxnprwpDS%2FCreate_Case_from_Folder.png?generation=1540056841004481\&alt=media)
Create an OpenFOAM Case from an existing case in a local folder. -
* **name \[Optional]**
  Optional new name to change the name of the case.
* **folder \[Required]**
  Fullpath to an OpenFoam case folder.
* **run \[Required]**
  Create case from inputs.
* **readMe!**
* **case**
  Butterfly case.
[Check Hydra Example Files for Create Case from Folder](https://hydrashare.github.io/hydra/index.html?keywords=Butterfly_Create%20Case%20from%20Folder)
