Color Network Results
Color a Dragonfly ElectricalNewtwork in the Rhino scene with OpenDSS simulation results.
  • data [Required]
A list of data collections of the same data type, which will be used to color the network with simulation results. These should come from the "DF Read OpenDSS Result" component.
  • network [Required]
A Dragonfly Electrical Newtork object to be colored with results in the Rhino scene.
  • sim_step
An optional integer (greater than or equal to 0) to select a specific step of the data collections for which result values will be generated. If None, the geometry will be colored with the maximum of resutls in the _data, essentially describing the peak condition. (Default: None).
  • period
A Ladybug analysis period to be applied to all of the input _data.
  • legend_par
An optional LegendParameter object to change the display of the colored output. (Default: None).
  • vis_geo
Meshes and line segments colored according to the results.
  • legend
Geometry representing the legend for colored objects.
  • title
A text object for the global title.
  • values
A list of values that align with the input substation, transformers and electrical connectors. These note the value assigned to each object.
  • colors
A list of colors that align with the input substation, transformers and electrical connectors. These note the color of each object in the Rhino scene.
