Deconstruct OpenDSS
Deconstruct an OpenDSS Wire, PowerLine, or Transformer Properties into its constituient attributes and values.
  • dss_obj [Required]
An OpenDSS Wire, PowerLine, or Transformer Properties to be deconstructed. This can also be text for a Wire, PowerLine, or Transformer to be looked up in the library.
  • values
List of values for the attributes that define the OpenDSS object.
  • attr_names
List of text that is the same length as the values, which notes the attribute name for each value.
