Electrical Connector
Create an OpenDSS Electrical Connector from linear geometry and power line properties, which include the wires and their geometrical arrangement.
  • geo [Required]
A line or polyline representing an Electrical Connector.
  • power_line [Required]
Text for the ID of a PowerLine carried along the electrical connector, which will be looked up in the Power Lines library (the output from the "DF OpenDSS Libraries" component). This can also be a custom PowerLine object created using the Ladybug Tools SDK.
Text to set the base name for the Electrical Connector, which will also be incorporated into unique ElectricalConnector identifier. If the name is not provided, a random one will be assigned.
  • connector
A Dragonfly Electrical Connector object that can be used within an Electrical Network.
