Fourth Generation Thermal Loop
Create an Fourth Generation Loop for a District Energy Simulation (DES) simulation.
This includes a central hot and chilled water plant for the district.
  • chilled_temp
A number for the temperature of chilled water in the DES in degrees Celsius. (Default: 6).
  • hot_temp
A number for the temperature of hot water in the DES in degrees Celsius. (Default: 54).
Text to be used for the name and identifier of the Thermal Loop. If no name is provided, it will be "unnamed".
  • des_loop
A Dragonfly Thermal Loop object possessing all infrastructure for a District Energy Simulation (DES) simulation. This should be connected to the loop_ input of the "DF Model to GeoJSON" component.
