> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/assign_model_uwg_properties.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/dragonfly-primer/~gitbook/mcp).
# Assign Model UWG Properties
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-31535976430fb4da1058d11e8cf5b3e6cd759a8c%2FAssign_Model_UWG_Properties.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-245f75a9fe8495415bff216d20921b35002d8f07%2FAssign_Model_UWG_Properties.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Assign%20Model%20UWG%20Properties.py)
Edit the properties of a Dragonfly Model that affect simulation with to the Urban Weather Generator (UWG).
* **model \[Required]**
  A Dragonfly Model which is to have its Urban Weather Generator (UWG) properties assigned.&#x20;
* **terrain**
  A Terrain object that dictates the properties of the street and ground beneath the buildings. If None, a default terrain object will be generated by analysing all of the buildings in the Model and drawing a bounding rectangle in the XY plane around them.&#x20;
* **traffic**
  A TrafficPararameter object that defines the activity and intensity of traffic within the urban street canyons. If None, traffic intensity will be approximated using the average building story count along with a generic traffic schedule.&#x20;
* **tree\_cover**
  A number from 0 to 1 that defines the fraction of the exposed terrain covered by trees. If None, it will be determined by evaluating the horizontal area of all ContextShade geometry that has a true is\_vegetation property.&#x20;
* **grass\_cover**
  A number from 0 to 1 that defines the fraction of the exposed terrain that is covered by grass or shrubs. If None, no grass will be assumed for the urban area.&#x20;
  ...&#x20;
* **model**
  The input Dragonfly Model with its UWG properties re-assigned based on the input.&#x20;
