> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/uwg_simulation_parameter.md).
# UWG Simulation Parameter
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-22fa74a92fad74d95a63d1351b0398ec2a8704cf%2FUWG_Simulation_Parameter.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-a78b50646717c91db5517ef21f530afe849da8fb%2FUWG_Simulation_Parameter.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20UWG%20Simulation%20Parameter.py)
Create a simulation parameter object that carries a complete set of Urban Weather Genreator (UWG) simulation settings and can be plugged into the "DF Run Urban Weather Generator" component.
* **run\_period**
A Ladybug Analysis Period object to describe the time period over which to run the simulation. If None, the simulation will be run for the whole year.
* **timestep**
An integer for the number of timesteps per hour at which the calculation will be run. (Default: 12).
* **veg\_par**
A VegetationParameter object to specify the behavior of vegetation in the urban area. If None, generic vegetation parameters will be generated.
* **epw\_site**
A ReferenceEPWSite object to specify the properties of the reference site where the input rural EPW was recorded. If None, generic airport properties will be generated.
* **bnd\_layer**
A BoundaryLayerParameter to specify the properties of the urban boundary layer. If None, generic boundary layer parameters will be generated.
* **sim\_par**
A UWG SimulationParameter object that can be connected to the "DF Run Urban Weather Generator" component in order to specify UWG simulation settings
