> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/write_ddy.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/dragonfly-primer/~gitbook/mcp).
# Write DDY
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-5e17e39d7c6adc1d499a30e9c52ecaba288c2a89%2FWrite_DDY.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-Ma9gBkJelXEQ5LsYEl7%2Fsync%2F5be7940f1a3829352d46e3fc7add53ca0aadffb1.png?generation=1621529559121355\&alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Write%20DDY.py)
Write Ladybug DesignDays to a standard .ddy file.
* **location \[Required]**
  A Ladybug Location object describing the location data in the weather file.&#x20;
* **design\_days \[Required]**
  A list of DesignDay objects representing the design days contained within the ddy file.&#x20;
* **folder**
  An optional folder to save the .ddy file.&#x20;
* **name**
  An optional name for this .ddy file.&#x20;
* **run \[Required]**
  Set to "True" to run the component and write the .ddy file.&#x20;
* **ddy\_file**
  A .ddy file path that has been written to your system.&#x20;
