> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/dragonfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/dragonfly-primer/components/6_alternativeweather/write_epw.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/dragonfly-primer/~gitbook/mcp).
# Write EPW
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-d22bba3338accb1479018d62bfa68934f8fa7aa9%2FWrite_EPW.png?alt=media)
![](https://3405893330-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9gBkJelXEQ5LsYEl7%2Fuploads%2Fgit-blob-321538fb6506b984f772d8c80bff0de9449f9680%2FWrite_EPW.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/dragonfly-grasshopper/blob/master/dragonfly_grasshopper/src//DF%20Write%20EPW.py)
Write an EPW object into a .epw file.
* **epw\_obj \[Required]**
  An EPW object such as that exported from the Create EPW component.&#x20;
* **folder**
  A directory into which the .epw file will be written.&#x20;
* **file\_name**
  An optional name for the .epw file. Default will use the city of the EPW object's location.&#x20;
* **run \[Required]**
  Set to True to run the component and write the .epw file.&#x20;
* **epw\_file**
  File path to a .epw that contains all of the data in the input \_epw\_obj.&#x20;
