> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/6_result/read_hvac_sizing.md).
# Read HVAC Sizing
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-12be53f2a7848318d7e4773b01d6595f43fdfb4b%2FRead_HVAC_Sizing.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-e7145c8f2d1fd59a423eb1fc449c74c43d4e890b%2FRead_HVAC_Sizing.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Read%20HVAC%20Sizing.py)
Parse the peak load and HVAC component sizes from an SQL result file that has been generated from an energy simulation.
* **sql \[Required]**
* **comp\_type**
An optional name of a HVAC component type, which will filter the HVAC components that appear in the output comp\_props and comp\_values. Connecting nothing here will mean that all HVAC component sizes are imported and a full list of possible components will appear in the comp\_types output.
* **zone\_names**
A list of zone names (honeybee Room identifiers) that correspond to the zone\_peak\_load and zone\_peak\_heat below.
* **zone\_peak\_cool**
A list of numbers for the peak cooling load of each zone on the summer design day. These correspond to the zone\_names above. All values are in Watts.
* **zone\_peak\_heat**
A list of numbers for the peak heating load of each zone on the winter design day. These correspond to the zone\_names above. All values are in Watts.
* **comp\_types**
A list of HVAC component types that are available in the results. This will be equal to the input comp\_type\_ if a value is connected.
* **comp\_properties**
A list of text descriptions for HVAC component properties. These correspond to the comp\_values below.
* **comp\_values**
Values denoting the size of various zone HVAC components (eg. zone terminal sizes, boiler/chiller sizes, lengths of chilled beams, etc.). These correspond to the comp\_properties above. Values may be in different units (eg. W, m/s, etc.) depending on the property of the component being observed.
