> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-energy-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-energy-primer/components/6_result/read_room_comfort_result.md).
# Read Room Comfort Result
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-3c15081de295ecae02e0ef9f5fb29b6dfeece0e2%2FRead_Room_Comfort_Result.png?alt=media)
![](https://459479801-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9N5K8lMbAhbyBVgms%2Fuploads%2Fgit-blob-c8c85575394e75bdf17ddfa1d4a94096f3a7588e%2FRead_Room_Comfort_Result.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-energy/blob/master/honeybee_grasshopper_energy/src//HB%20Read%20Room%20Comfort%20Result.py)
Parse all of the common Room-level comfort-related results from an SQL result file that has been generated from an energy simulation.
* **sql \[Required]**
* **oper\_temp**
DataCollections for the mean operative temperature of each room (C).
* **air\_temp**
DataCollections for the mean air temperature of each room (C).
* **rad\_temp**
DataCollections for the mean radiant temperature of each room (C).
* **rel\_humidity**
DataCollections for the relative humidity of each room (%).
* **unmet\_heat**
DataCollections for time that the heating setpoint is not met in each room (hours).
* **unmet\_cool**
DataCollections for time that the cooling setpoint is not met in each room (hours).
