> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/1_modifiers/interior_modifier_subset.md).
# Interior Modifier Subset
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-6764f5e5c9b3ddc05b99a6ca1f10beb1df3e7e19%2FInterior_Modifier_Subset.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-049edbc0869f14de73031dc46a921890863e496b%2FInterior_Modifier_Subset.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Interior%20Modifier%20Subset.py)
Create a list of interior modifiers that can be used to edit or create a ModifierSet object.
* #### interior\_wall
A modifier object for interior walls (or text for the identifier of the modifier within the library).
* #### ceiling
A modifier object for ceilings (or text for the identifier of the modifier within the library).
* #### interior\_floor
A modifier object for interior floors (or text for the identifier of the modifier within the library).
* #### interior\_window
A modifier object for all apertures with a Surface boundary condition. This can also be text for the identifier of the modifier within the library.
* #### interior\_door
A modifier object for all opaque doors with a Surface boundary condition. This can also be text for the identifier of the modifier within the library.
* #### int\_glass\_door
A modifier object for all glass doors with a Surface boundary condition. This can also be text for the identifier of the modifier within the library.
* #### interior\_set
A list of interior modifiers that can be used to edit or create a ModifierSet object.
