> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/2_lightsources/visualize_luminaire.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-radiance-primer/~gitbook/mcp).
# Visualize Luminaire
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-c322a7cde702b752e34884a0940446fb5cb827e5%2FVisualize_Luminaire.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-b56716674b1e8d17508657fdf3d9a8fc7cbaa390%2FVisualize_Luminaire.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Visualize%20Luminaire.py)
Visualize a Luminaire.
This is useful to check if the the spin, tilt, and rotation is applied correctly.
* #### luminaire \[Required]
A Honeybee Luminaire.
* #### scale
A scalar value to scale the geometry. By default the geometry is normalized to Rhino model units as a base scale. The scalar value is multiplied with this base scale.
* #### report
* #### lum\_poly
Geometric representation of the luminous opening.
* #### lum\_web
Geometric representation of the candela distribution of the luminaire.
* #### lum\_axes
Line representation of the C0-G0 axes of the luminaire.
