LEED Option I
Run a LEED v4.1 Daylight Option 1 daylight study for a Honeybee model.
This recipe computes Spatial Daylight Autonomy (sDA) and Annual Sun Exposure (ASE) in accordance with the IES LM-83-12 methodology required for LEED certification. It automates the multi-phase simulation required to model dynamic blinds/shades, evaluating whether 2% or more of the room's sensors experience direct sunlight (>=1000 lux) for each hour of the year. The post-processing is using a 8AM-6PM occupancy schedule.
SIMULATION REQUIREMENTS: * ROOMS: The model must consist of Honeybee Rooms. * APERTURE GROUPS: For dynamic shading to work, you must assign aperture groups to your Honeybee Apertures through "HB Automatic Aperture Group" (room_based must be True) or "HB Dynamic Aperture Group" for more control of the grouping.
A Honeybee Model for which LEED Option 1 will be simulated. Note that this model must have grids assigned to it. It is also required that the model consists of rooms and that aperture groups be assigned to exterior apertures.
A Wea object produced from the Wea components that are under the Light Sources tab. This can also be the path to a .wea or a .epw file. Note that the Wea must have a timestep of 1 to be used with this recipe.
Text for a grid identifer or a pattern to filter the sensor grids of the model that are simulated. For instance, first_floor_* will simulate only the sensor grids that have an identifier that starts with first_floor_. By default, all grids in the model will be simulated.
A fractional number between 0 and 1 representing the diffuse visible transmittance of the dynamic blinds/shades when closed.
A fractional number between 0 and 1 representing the specular visible transmittance of the dynamic blinds/shades when closed.
Raw result files (.ill) that contain illuminance matrices for each sensor at each hour of the simulation. These can be postprocessed using various components under the 4::Results sub-tab. Note that these results are without dynamic shading.
A summary detailing the total LEED points and overall model compliance statistics for sDA and ASE for the entire model.
A detailed room-by-room breakdown showing sDA, ASE, and floor area compliance for each individual space.
A list of Ladybug Data Collection, where each collection represents the dynamic schedule for an aperture group. The schedules can be visualized with the 'Hourly Plot' component.
Daylight Autonomy (DA) results in percent (0 to 100) for each sensor under the calculated dynamic blind schedules.
The number of occupied hours where each sensor receives direct solar illuminance above 1000 lux (used to compute ASE).
A list of Ladybug Data Collections, where each collection corresponds to a single sensor grid. The hourly values represent the percentage (%) of the grid's total floor area receiving direct sunlight illuminance above 1000 lux. The Data Collections can be visualized with the 'Hourly Plot' component.
