LEED Option II
Run a LEED v4.1 Daylight Option 2 point-in-time study for a Honeybee model.
This recipe calculates illuminance for two specific times on a clear sky day near the equinox: 9:00 AM and 3:00 PM. It determines compliance based on whether sensor points fall within the target luxury range.
GLARE CONTROL LOGIC: * If 'glr_ctrl' is set to True, the space is assumed to possess view-preserving automatic glare-control devices. Consequently, sensor points only need to achieve an illuminance level above 300 lux to pass. * If 'glr_ctrl' is set to False, sensor points must fall strictly between 300 lux and 3,000 lux to be considered compliant.
  • model [Required]
A Honeybee Model for which LEED Option II will be simulated. Note that this model must have grids assigned to it.
  • wea [Required]
A Wea object produced from the Wea components that are under the Light Sources tab. This can also be the path to a .wea or a .epw file. Note that the Wea must have a timestep of 1 to be used with this recipe.
  • north
  • grid_filter
Text for a grid identifer or a pattern to filter the sensor grids of the model that are simulated. For instance, first_floor_* will simulate only the sensor grids that have an identifier that starts with first_floor_. By default, all grids in the model will be simulated.
  • radiance_par
  • glr_ctrl
Set to True to specify that the model has view-preserving automatic (with manual override) glare-control devices. (Default: True).
  • run_settings
  • run [Required]
  • credit_summary
A summary containing the number of LEED credits achieved and the percentage of the floor area that meets the criteria.
  • space_summary
A detailed summary for each grid containing the percentage floor area each space that meets the compliance criteria.
  • combined_compliance
Binary (1/0) for pass/fail evaluation results for both 9 AM and 3 PM. Points must pass at BOTH 9 AM and 3 PM.
  • illuminance_9am
Illuminance (lux) values for the 9:00 AM simulation.
  • illuminance_3pm
Illuminance (lux) values for the 3:00 PM simulation.
  • compliance_9am
Binary (1/0) pass/fail evaluation results for the 9:00 AM simulation state.
  • compliance_3pm
Binary (1/0) pass/fail evaluation results for the 3:00 PM simulation state.
