> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/3_recipes/leed_option_ii.md).
# LEED Option II
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-cd66ca2a85f93383cd30d34167adafe98c8eb97d%2FLEED_Option_II.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-5fb5d38e102a968627c0450789baa0a6024092a6%2FLEED_Option_II.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20LEED%20Option%20II.py)
Run a LEED v4.1 Daylight Option 2 point-in-time study for a Honeybee model.
This recipe calculates illuminance for two specific times on a clear sky day near the equinox: 9:00 AM and 3:00 PM. It determines compliance based on whether sensor points fall within the target luxury range.
GLARE CONTROL LOGIC: \* If '*glr\_ctrl*' is set to True, the space is assumed to possess view-preserving automatic glare-control devices. Consequently, sensor points only need to achieve an illuminance level above 300 lux to pass. \* If '*glr\_ctrl*' is set to False, sensor points must fall strictly between 300 lux and 3,000 lux to be considered compliant.
* #### model \[Required]
A Honeybee Model for which LEED Option II will be simulated. Note that this model must have grids assigned to it.
* #### wea \[Required]
A Wea object produced from the Wea components that are under the Light Sources tab. This can also be the path to a .wea or a .epw file. Note that the Wea must have a timestep of 1 to be used with this recipe.
* #### north
* #### grid\_filter
Text for a grid identifer or a pattern to filter the sensor grids of the model that are simulated. For instance, first\_floor\_\* will simulate only the sensor grids that have an identifier that starts with first\_floor\_. By default, all grids in the model will be simulated.
* #### radiance\_par
* #### glr\_ctrl
Set to True to specify that the model has view-preserving automatic (with manual override) glare-control devices. (Default: True).
* #### run\_settings
* #### run \[Required]
* #### report
* #### credit\_summary
A summary containing the number of LEED credits achieved and the percentage of the floor area that meets the criteria.
* #### space\_summary
A detailed summary for each grid containing the percentage floor area each space that meets the compliance criteria.
* #### combined\_compliance
Binary (1/0) for pass/fail evaluation results for both 9 AM and 3 PM. Points must pass at BOTH 9 AM and 3 PM.
* #### illuminance\_9am
Illuminance (lux) values for the 9:00 AM simulation.
* #### illuminance\_3pm
Illuminance (lux) values for the 3:00 PM simulation.
* #### compliance\_9am
Binary (1/0) pass/fail evaluation results for the 9:00 AM simulation state.
* #### compliance\_3pm
Binary (1/0) pass/fail evaluation results for the 3:00 PM simulation state.
