# Page Not Found
The URL `components/4_results/annual_results_to_dat` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Annual Results to Data](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_results_to_data.md)
- [Annual Statistics](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_statistics.md)
- [Annual Cumulative Values](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_cumulative_values.md)
- [Annual Peak Values](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_peak_values.md)
- [Annual Sunlight Exposure](https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_sunlight_exposure.md)
GET https://docs.ladybug.tools/hb-radiance-primer/components/4_results/annual_results_to_data.md?ask=<question>&goal=<user_goal>
Full index: https://docs.ladybug.tools/hb-radiance-primer/sitemap.md
Full export: https://docs.ladybug.tools/hb-radiance-primer/llms-full.txt
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/hb-radiance-primer/components/4_results/annual_results_to_data.md`).
