> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/1_analyzedata/humidity_metrics.md).
# Humidity Metrics
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-a321c8d37fb5996c942b3bea69339afd934ec813%2FHumidity_Metrics.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-4e66a524941cc025dda5a5b0a459e7371862895f%2FHumidity_Metrics.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Humidity%20Metrics.py)
Calculate humidity metrics from relative humidity, dry bulb temperature and (if present) atmospheric pressure.
* **dry\_bulb \[Required]**
A value or data collection representing dry bulb temperature \[C]
* **rel\_humid \[Required]**
A value or data collection representing relative humidity \[%]
* **pressure**
A value or data collection representing atmospheric pressure \[Pa] Default is to use air pressure at sea level (101,325 Pa).
* **humid\_ratio**
A data collection or value for humidity ratio (aka. absolute humidity). Units are fractional (kg water / kg air).
* **enthalpy**
A data collection or value for enthalpy (kJ / Kg).
* **wet\_bulb**
A data collection or value for wet bulb temperature (C).
* **dew\_point**
A data collection or value for dew point temperature (C).
