Generate fvSchemes based on mesh non-orthogonalities. -
quality [Required]
Solution quality [0..1]. The quality 0 generates divSchemes
which is less accurate but more stable. The quality 1 generates a
divSchemes that are more accurate but less stable. You can start with
quality 0 and then change it to quality 1 when the solution is
converging.
divSchemes
Recommended divSchemes. Use solution parameter to update
fvSchemes for the solution.
Check Hydra Example Files for divSchemes libraryarrow-up-right
Last updated 7 years ago
Was this helpful?
