IB PlantLoop
The main elements of the PlantLoop syntax are described in further detail below. A map of how the input for this portion of the HVAC input fits together is provided in the following diagram. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
supply [Required]
HVAC components
demand [Required]
HVAC components
sizing
HVAC components
scheme
HVAC components
plantLoop
plantLoop
