There is no component description available now! Please stay tuned or contribute :> Source code: https://github.com/MingboPeng/Ironbug
airHiT
High control air temperature, above which the cooling will be turned on
Coil
Add to ZoneHVACLowTempRadiantVarFlow
ToWaterLoop
Connect to hot water loop's demand side via plantBranches
Last updated 1 month ago
