IB AvailabilityManagerHybridVentilation
There is no component description available now! Please stay tuned or contribute :> Source code: https://github.com/MingboPeng/Ironbug
  • ctrlZone [Required]
A controlled zone served by the air loop defined. The air conditions in this zone are used to determine if natural ventilation should be provided.
  • AM
TODO..
