IB CurveFanPressureRise
Input for a cubic curve consists of the curve name, the 4 coefficients, and the maximum and minimum valid independent variable values. Optional inputs for curve minimum and maximum may be used to limit the output of the performance curve (e.g., limit extrapolation). The equation represented by the cubic curve is: y = {C_1} + {C_2}x + {C_3}{x^2} + {C_4}*{x^3} Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
  • coeffs [Required]
A list of coefficients for a FanPressureRise curve from C1 to C4.
  • Curve
