IB GeneratorPhotovoltaic
This object is used to describe an array of PV modules and how they are to be modeled. A series of different PV arrays can be connected to a single electric load center (and inverter) by listing them all in an ElectricLoadCenter:Generator object. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
  • surface [Required]
A Honeybee Shade
  • performance
This field is the type of PV performance model. The choices are the class names for the three modeling options: {PhotovoltaicPerformance:Simple} {PhotovoltaicPerformance:EquivalentOne-Diode} {PhotovoltaicPerformance:Sandia}.
  • generator
generator
