RAS_Turbulance_Model
Reynolds-averaged simulation (RAS) turbulence model. Read more: http://cfd.direct/openfoam/user-guide/turbulence/arrow-up-right Watch this: https://www.youtube.com/watch?v=Eu_4ppppQmwarrow-up-right
  • RASModel [Default]
    Name of RAS turbulence model (default: RNGkEpsilon).
    Incompressible RAS turbulence models.
    LRR, LamBremhorstKE, LaunderSharmaKE, LienCubicKE,
    LienLeschziner, RNGkEpsilon, SSG, ShihQuadraticKE,
    SpalartAllmaras, kEpsilon, kOmega, kOmegaSSTSAS, kkLOmega,
    qZeta, realizableKE, v2f
    Compressible RAS turbulence models.
    LRR, LaunderSharmaKE, RNGkEpsilon, SSG, SpalartAllmaras,
    buoyantKEpsilon, kEpsilon, kOmega, kOmegaSSTSAS,
    realizableKE, v2f
  • turbulence [Default]
    Boolean switch to turn the solving of turbulence
    modelling on/off (default: True).
  • printCoeffs [Default]
    Boolean switch to print model coeffs to terminal at
    simulation start up (default: True).
  • RAS
    Script variable Python
Check Hydra Example Files for RAS Turbulance Modelarrow-up-right
Was this helpful?
