LES_Turbulance_Model
Large eddy simulation (LES) modelling. Read more: http://cfd.direct/openfoam/user-guide/turbulence/arrow-up-right Watch this: https://www.youtube.com/watch?v=Eu_4ppppQmwarrow-up-right
  • LESModel [Default]
    Name of LES turbulence model.
    Incompressible LES turbulence models.
    DeardorffDiffStress, Smagorinsky, SpalartAllmarasDDES,
    SpalartAllmarasDES, SpalartAllmarasIDDES, WALE, dynamicKEqn,
    dynamicLagrangian, kEqn, kOmegaSSTDES
    Compressible LES turbulence models.
  • delta [Default]
    Name of delta model.
  • turbulence [Default]
    Boolean switch to turn the solving of turbulence
    modelling on/off (default: True).
  • printCoeffs [Default]
    Boolean switch to print model coeffs to terminal at
    simulation start up (default: True).
  • LES
    Script variable Python
Check Hydra Example Files for LES Turbulance Modelarrow-up-right
Was this helpful?
