Plot_Residuals
Load residual values for a case. -
  • solution [Required]
    A Butterfly recipe.
  • rect [Required]
    A rectangle for boundary chart.
  • fields [Default]
    Residual fields. If empty solution's fields will be used.
  • targetRes [Default]
    Residential number that will be added to the graph as a black line.
  • timeRange [Optional]
    timeRange for loading residuals as a domain.
  • method [Optional]
    Method of ploting the values (0..1). 0: Curves, 1: Colored mesh
    If you're updating the values frequently use method 1 which is the
    quicker method.
  • load [Required]
    Script variable loadResiduals
  • readMe!
    Reports, erros, warnings, etc.
  • timeRange
    Total time range.
  • curves
    Lines as curves.
  • residualLine
    Residual line.
  • colors
    List of colors for meshes to color text, etc.
Check Hydra Example Files for Plot Residualsarrow-up-right
Was this helpful?
