Sample_Case
Sample the results for a case. Use this component yo load the results for a case that you have ran already. -
  • solution [Required]
    Butterfly Solution, Case or fullpath to the case folder.
  • name [Required]
    A name for this smaple. The results will be saved under postProcessing
    folder under _sampleDict//.xy
  • points [Required]
    A list of flattened points to be sampled.
  • field [Required]
    Filed of interest as a string (e.g. p, U).
  • run [Required]
    Set to true to run the sample.
  • readMe!
    The execution information, as output and error streams
  • probes
    List of probes as points. This list should be identical to the input
    _points if there is no skipped points.
  • values
    List of values as numbers or vectors.
Check Hydra Example Files for Sample Casearrow-up-right
Was this helpful?
