FF Cavity Material
Create a custom cavity material, which can be plugged into the "FF Shape" component to change the properties of the material in a THERM simulation.
name
Text to set the name for the material.
cavity_model
Text for the type of cavity model to be used to determine the thermal resistance of the material. (Default: CEN). Choose from the following.
gas_type
Text describing the types of gas in the gap. (Default: Air). Text must be one of the following: 'Air', 'Argon', 'Krypton', 'Xenon'.
rgb_color
An optional color to set the color of the material when it is imported to THERM. If unspecified, a randomly-generated color is assigned.
mat
A cavity material that can be assigned to a Fairyfly Shape to change the properties of the material in a THERM simulation.
