FF Solid Material
Create a custom solid material, which can be plugged into the "FF Shape" component to change the properties of the material in a THERM simulation.
name
Text to set the name for the material.
conductivity [Required]
Number for the thermal conductivity of the material [W/m-K].
emissivity
Number between 0 and 1 for the infrared hemispherical emissivity of the material. (Default: 0.9).
density
Number for the density of the material [kg/m3].
porosity
Optional number between 0 and 1 for the porosity of the material.
spec_heat
Number for the specific heat of the material [J/kg-K].
vapor_resist
Optional number for the water vapor diffusion resistance factor.
rgb_color
An optional color to set the color of the material when it is imported to THERM. If unspecified, a randomly-generated color is assigned.
mat
A standard solid material that can be assigned to a Fairyfly Shape to change the properties of the material in a THERM simulation.
