# Page Not Found
The URL `components/3_energy/color_network_results` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Color Network Results](https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/color_network_results.md)
- [Color Network Attributes](https://docs.ladybug.tools/dragonfly-primer/components/1_visualize/color_network_attributes.md)
- [Run REopt](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/run_reopt.md)
- [Load Mapper Measure](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/load_mapper_measure.md)
- [Reassign Energy Properties](https://docs.ladybug.tools/dragonfly-primer/components/3_energy/reassign_energy_properties.md)
GET https://docs.ladybug.tools/dragonfly-primer/components/4_electricgrid/color_network_results.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/dragonfly-primer/components/4_electricgrid/color_network_results.md`).
