This simple heating coil model only does sensible heating of the air. The simple heating coil uses the Effectiveness-NTU algorithm and assumes a cross-flow heat exchanger. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
Coil
connect to air loop's supply side or other water heated system.
ToWaterLoop
connect to hot water loop's demand side via plantBranches
Last updated 1 month ago
