This simple heating coil model only does sensible heating of the air. The simple heating coil uses the Effectiveness-NTU algorithm and assumes a cross-flow heat exchanger. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
ctrl [Required]
add a customized controller here
Coil
connect to air loop's supply side or other water heated system.
ToWaterLoop
connect to hot water loop's demand side via plantBranches
Last updated 1 month ago
