The EIR-formulated cooling model objects are described. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
CompanionHtnHP
CompanionHeatingHeatPump
ClnHP
Connect to chilled water loop's supply side.
ToCondenser
Connect to condenser loop's demand side.
Last updated 1 month ago
