When the user is not interested in a plant simulation or there is some centralized source of chilled water, the following object can be used in the input. Above content copyright © 1996-2025 EnergyPlus, all contributors. All rights reserved. EnergyPlus is a trademark of the US Department of Energy.
DistCooling
DistrictCooling for plant loop's supply.
Last updated 1 month ago
