Luminaire Zone
Create a Honeybee LuminaireZone of LuminaireInstances.
It is recommended to apply the rotation in the following order: spin, tilt, rotation. If an aiming point is added it will override any spin, tilt, and rotation values.
  • points [Required]
A point or list of points that will be used to position the luminaires.
  • spin
Rotation about the local vertical axis (degrees), This axis is also called the G0 axis. Default: 0.
  • tilt
Tilt angle around the Y axis (degrees). Default: 0.
  • rotation
Rotation angle around the Z axis (degrees). Default: 0.
  • aiming_point
A point representing the location at which the photometric axis of the luminaires should be aimed. This can also be a list of points that matches the length of _points.
  • luminaire_zone
A LuminaireZone that can be plugged into a Luminaire.
