> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/hb-radiance-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/hb-radiance-primer/components/2_lightsources/custom_sky.md). Agents can also search and read this documentation through its [MCP server](https://docs.ladybug.tools/hb-radiance-primer/~gitbook/mcp).
# Custom Sky
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-fb1e3cbcd527411b75825fd5f3fc54be2c75614f%2FCustom_Sky.png?alt=media)
![](https://2572426507-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-Ma9X8PomX22wWVDNCoj%2Fuploads%2Fgit-blob-a97ce1555f8f366dbe7727d22a40946a04294d09%2FCustom_Sky.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-radiance/blob/master/honeybee_grasshopper_radiance/src//HB%20Custom%20Sky.py)
Create a Custom sky from direct and diffuse irradiance.
* #### north
A number between 0 and 360 that represents the degrees off from the y-axis to make North. This can also be a vector to set the North. Default is 0. The default North direction is the Y-axis (0 degrees).
* #### location \[Required]
A Ladybug location object.
* #### dir\_rad \[Required]
Direct normal irradiance (W/m2).
* #### diff\_rad \[Required]
Diffuse horizontal irradiance (W/m2).
* #### month
An integer between 1 and 12 for the month of the year (default: 6).
* #### day
An integer between 1 and 31 for the day of the month (default: 21).
* #### hour
A number between 0 and 23.999 for the hour of the day (default: 12).
* #### colored
Boolean to note whether the sky will be rendered in full color (True) or it will simple be a grey sky with the same average value as the colored sky (False). (Default: False).
* #### sky
Honeybee sky. You can use this sky to create a daylight recipe.
