CIE Standard Sky
Create a point-in-time standard Radiance CIE sky.
A number between 0 and 360 that represents the degrees off from the y-axis to make North. This can also be a vector to set the North. Default is 0. The default North direction is the Y-axis (0 degrees).
A Ladybug location object.
An integer between 1 and 12 for the month of the year (default: 6).
An integer between 1 and 31 for the day of the month (default: 21).
A number between 0 and 23.999 for the hour of the day (default: 12).
An integer between 0..5 to indicate CIE Sky Type (default: 0).
A honeybee sky that can be used to create a point-in-time recipe.
