Subface Subset
Create a list of exterior subface (apertures + doors) constructions that can be used to edit or create a ConstructionSet object.
  • window
    A construction object for apertures with an Outdoors boundary condition and a Wall face type for their parent face. This can also be text for the identifier of the construction within the library.
  • skylight
    A construction object for apertures with an Outdoors boundary condition and a RoofCeiling or Floor face type for their parent face. This can also be text for the identifier of the construction within the library.
  • operable
    A construction object for apertures with an Outdoors boundary condition and True is_operable property. This can also be text for the identifier of the construction within the library.
  • exterior_door
    A construction object for opaque doors with an Outdoors boundary condition and a Wall face type for their parent face. This can also be text for the identifier of the construction within the library.
  • overhead_door
    A construction object for opaque doors with an Outdoors boundary condition and a RoofCeiling or Floor face type for their parent face. This can also be text for the identifier of the construction within the library.
  • glass_door
    A construction object for all glass doors with an Outdoors boundary condition. This can also be text for the identifier of the construction within the library.
  • subface_set
    A list of exterior subface constructions that can be used to edit or create a ConstructionSet object.
