Ground Construction Subset
Create a list of ground constructions that can be used to edit or create a ConstructionSet object.
  • ground_wall
    A construction object for underground walls (or text for the identifier of the construction within the library).
  • ground_roof
    A construction object for underground roofs (or text for the identifier of the construction within the library).
  • ground_floor
    A construction object for ground-contact floors (or text for the identifier of the construction within the library).
  • ground_set
    A list of ground constructions that can be used to edit or create a ConstructionSet object.
