Interior Construction Subset
Create a list of interior constructions that can be used to edit or create a ConstructionSet object.
  • interior_wall
    A construction object for interior walls (or text for the identifier of the construction within the library).
  • ceiling
    A construction object for ceilings (or text for the identifier of the construction within the library).
  • interior_floor
    A construction object for interior floors (or text for the identifier of the construction within the library).
  • interior_window
    A construction object for all apertures with a Surface boundary condition. This can also be text for the identifier of the construction within the library.
  • interior_door
    A construction object for all opaque doors with a Surface boundary condition. This can also be text for the identifier of the construction within the library.
  • int_glass_door
    A construction object for all glass doors with a Surface boundary condition. This can also be text for the identifier of the construction within the library.
  • interior_set
    A list of interior constructions that can be used to edit or create a ConstructionSet object.
