Create_Case_from_Geometries
Create an OpenFOAM Case from geometries. -
  • name [Required]
    Project name.
  • BFGeometries [Required]
    List of butterfly geometries for this case.
  • refRegions [Optional]
    A list of refinement regions.
  • make2dParams [Optional]
    Butterfly parameters to make a 2d wind tunnel.
  • meshParams [Default]
    Butterfly meshing parameters. You can set-up meshing parameters
    also on the blockMesh and snappyHexMesh components to overwrite this
    settings. Use this input to set up the meshing parameters if you are
    not running the meshing locally.
  • expandBlockMesh [Optional]
    Butterfly by default expands the mesh by one cell to
    ensure snappyHexMesh will snap to extrior surfaces. You can set the
    expand to off or overwrite the vertices using update blockMeshDict
    component.
  • run [Required]
    Create case from inputs.
  • readMe!
  • blockPts
    Script variable caseFromGeos
  • case
    Butterfly case.
Check Hydra Example Files for Create Case from Geometriesarrow-up-right
Was this helpful?
