> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/butterfly-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/butterfly-primer/components/06_solution/solution_parameter.md).
# Solution\_Parameter
![](https://3867130239-files.gitbook.io/~/files/v0/b/gitbook-legacy-files/o/assets%2F-LPHXQ1CBjfLUuUW94tN%2F-LPHXSV32c4bM8DFZc3w%2F-LPHXa-uA07tx9TTQo0e%2FSolution_Parameter.png?generation=1540056844605348\&alt=media)
Solution Parameter.
* **filename \[Required]**
  OpenFOAM filename that the values are belong to (e.g.
  blockMeshDict, fvSchemes).
* **values \[Required]**
  new values as a valid OpenFOAM (c++) dictionary.
* **tRange \[Optional]**
  Script variable solutionParam
* **replace \[Optional]**
  Set to True if you want the original dictionary to be replaced
  by new values. Default is False which means the original dictionary
  will be only updated by new values.
* **solutionParam**
  A solution parameter.
[Check Hydra Example Files for Solution Parameter](https://hydrashare.github.io/hydra/index.html?keywords=Butterfly_Solution%20Parameter)
