Legend 2D Parameters
Customize the properties of a screen-oreinted 2D legend displaying with the "LB Preview VisualizationSet" component.
  • origin_x
An integer in pixels to note the X coordinate of the base point from where the 2D legend will be generated (assuming an origin in the upper-left corner of the screen with higher positive values of X moving to the right). Alternatively, this can be a text string ending in a % sign to denote the percentage of the screen where the X coordinate exists (eg. 5%). The default is set to make the legend clearly visible in the upper-left corner of the screen (10 pixels).
  • origin_y
An integer in pixels to note the Y coordinate of the base point from where the legend will be generated (assuming an origin in the upper-left corner of the screen with higher positive values of Y moving downward). Alternatively, this can be a text string ending in a % sign to denote the percentage of the screen where the X coordinate exists (eg. 5%). The default is set to make the legend clearly visible in the upper-left corner of the screen (50 pixels).
  • seg_height
A integer in pixels to note the height for each of the legend segments. Alternatively, this can be a text string ending in a % sign to denote the percentage of the screen (eg. 5%). The default is set to make most legends readable on standard resolution screens (25px for horizontal and 36px for vertical).
  • seg_width
An integer in pixels to set the width of each of the legend segments. Alternatively, this can be a text string ending in a % sign to denote the percentage of the screen (eg. 5%). The default is set to make most legends readable on standard resolution screens (36px for horizontal and 25px for vertical).
  • text_height
An integer in pixels to set the height for the legend text. Alternatively, this can be a text string ending in a % sign to denote the percentage of the screen (eg. 2%).
  • leg_par2d
A legend parameter object that can be plugged into any of the Ladybug components with a legend.
