> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/4_extra/dump_data.md).
# Dump Data
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-f31114530839174a591847893eb2ee66cc312db6%2FDump_Data.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-da7138d6016dbd2f818f64c6e50baea26e662224%2FDump_Data.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Dump%20Data.py)
Dump any Ladybug data collections into a file. You can use "LB Load Data" component to load the data collections from the file back into Grasshopper.
* **data \[Required]**
A list of Ladybug data collections to be written to a file.
* **format**
Text or an integer to set the format of the output file. Choose from the options below. (Default: CSV).
* 0 = CSV - Compact, human-readable, importable to spreadsheets
* 1 = JSON - Cross-language and handles any types of collections
* 2 = PKL - Compressed format only readable with Python
* **name**
A name for the file to which the data collections will be written. (Default: 'data').
* **folder**
An optional directory into which the data collections will be written. The default is set to a user-specific simulation folder.
* **dump \[Required]**
Set to "True" to save the data collection to a file.
Errors, warnings, etc.
* **data\_file**
The path of the file where the data collections are saved.
