> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/4_extra/dump_visualizationset.md).
# Dump VisualizationSet
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-6dd7485068f3cf4763af6708c4c3dc7dad422f38%2FDump_VisualizationSet.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-34b8219d243854653a21e4c9c7cfdbc69e21fa58%2FDump_VisualizationSet.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Dump%20VisualizationSet.py)
Dump a Ladybug VisualiztionSet into a file.
The "LB Preview VisualizationSet" component can be used to visualize the content from the file back into Grasshopper.
* **vis\_set \[Required]**
A VisualizationSet object to be written to a file. This can also be VisualizationSet arguments from any Ladybug Tools component with a vis\_set output.
* **format**
Text or an integer to set the format of the output file. Choose from the options below. (Default: SVG).
* 0 = SVG - Interactive Scaleable Vector Graphic for web browsers
* 1 = JSON - Cross-language and handles any types of collections
* 2 = PKL - Compressed format only readable with Python
* **svg\_view**
An optional text string for the view for which the SVG will be generated. Choose from the options below. (Default: Top).
* Top
* Left
* Right
* Front
* Back
* NE
* NW
* SE
* SW
* **svg\_width**
The screen width in pixels. (Default: 800).
* **svg\_height**
The screen height in pixels. (Default: 600).
* **legend\_2d**
A boolean to note whether the geometry in the visulaization set should be rendered using the 2D Legend Parameters instead of the 3D ones. (Default: False).
* **name**
A name for the file to which the VisualizationSet will be written. The default is derived from the identifier of the visualization set.
* **folder**
An optional directory into which the VisualizationSet will be written. The default is set to a user-specific simulation folder.
* **dump \[Required]**
Set to "True" to save the VisualizationSet to a file.
Errors, warnings, etc.
* **vs\_file**
The path of the file where the VisualisationSet is saved. The "LB Preview VisualizationSet" component can be used to visualize the content from the file back into Grasshopper.
