> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/4_extra/set_view.md).
# Set View
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-baaac88d9aae2e793d9f59ae4a5b5f36bca444f7%2FSet_View.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-147a8626e09dae1be026375e79059fafa30a0313%2FSet_View.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Set%20View.py)
Open a new viewport in Rhino that shows the parallel-projected view from the sun.
This is useful for understanding what parts of Rhino geometry are shaded at a particular hour of the day.
* **direction \[Required]**
A vector for the direction that the viewport camera faces.
* **position**
A point for the position of the vieport camera in 3D space. If no point is provided, the Rhino origin will be used (0, 0, 0).
* **look\_around**
Optional 2D point (aka. UV coordinates) to tilt the viewport camera off from from the input \_direction. Values for UV coordinates must be between 0 and 1 and these correspond to a tilt of 90 degrees in either direction (with 0.5, 0.5 being centered on the \_direction). Inputting a native Grasshopper Slider MD component will allow the most control of view offsetting.
* **width**
An optional interger for the width (in pixels) of the Rhino viewport that will be generated.
* **height**
An optional interger for the height (in pixels) of the Rhino viewport that will be generated.
* **lens\_len**
An optional number that sets the lens length of the viewport camera in mm. Typical values are around 20-50mm but wider angle views can be achieved by lowering this number to 10 or less. If unspecified, the lens length of the currently active Rhino viewport will be used.
* **mode**
An optional text input for the display mode of the Rhino viewport that will be generated. For example: Wireframe, Shaded, Rendered, etc. If unspecified, the mode of the currenlty active Rhino viewport will be used
The name of the viewport that was opened.
