> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/ladybug-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/ladybug-primer/components/4_extra/screen_oriented_text.md).
# Screen Oriented Text
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-63953cc95383417c7b5d8be8aafb6ad4c681f443%2FScreen_Oriented_Text.png?alt=media)
![](https://894783789-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1I3gb93zpLrLZf%2Fuploads%2Fgit-blob-d8b3530414fbbcc6f778a6cd81e012ad27574df5%2FScreen_Oriented_Text.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/ladybug-grasshopper/blob/master/ladybug_grasshopper/src//LB%20Screen%20Oriented%20Text.py)
Generate screen-oriented text that displays in the Rhino scene as a head-up display (HUD).
This is useful when there are certain summary results or information that should always be displayed on-screen.
* **text \[Required]**
Text string to be displayed in the plane of the screen.
* **leg\_par2d**
Optional 2D LegendParameters from the "LB Legend Parameters 2D" component, which will be used to customize a text in the plane of the screen. Note that only the text\_height, origin\_x and origin\_y inputs of this component affect the placement of the text.
* **font**
An optional text string to specify the font to be used for the text. Examples include "Arial", "Times New Roman", "Courier" (all without quotations). Default is "Arial".
* **color**
An optional color to set the color of the text. If unspecified, it will be black.
* **viewport**
Text for the name of the Rhino viewport to which the 2D screen-oriented text will be rendered. Multiple viewports can be connected to have the text display in several viewports. If unspecified, the text is rendered in all viewports. Acceptable inputs include: Perspective Top Bottom Left Right Front Back any view name that has been saved within the Rhino file
