> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/honeybee-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/honeybee-primer/components/0_create/facade_parameters.md).
# Facade Parameters
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-3a4a3ed68b8e563fdaa29a10ee99f935a504f9a9%2FFacade_Parameters.png?alt=media)
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-edcc44f383f2b34f22187c51427ce66465c889ed%2FFacade_Parameters.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-core/blob/master/honeybee_grasshopper_core/src//HB%20Facade%20Parameters.py)
Generate lists of facadce properties ordanized by the four primary cardinal directions.
Such properties can be glazing ratios, glazing heigths, sill heights, horizontal/ vertical glazing splits for the "HB Apertures by Ratio" component. Or they could be shade depths, angles, etc. for the "HB Louver Shades" component.
* **north**
  Glazing parameter (boolean, float) for the north.&#x20;
* **east**
  Glazing parameter (boolean, float) for the east.&#x20;
* **south**
  Glazing parameter (boolean, float) for the south.&#x20;
* **west**
  Glazing parameter (boolean, float) for the west.&#x20;
* **fac\_par**
  A list of properties for different cardinal directions to be plugged into the "HB Apertures by Ratio" component or the "HB Louver Shades" component.&#x20;
