> For the complete documentation index, see [llms.txt](https://docs.ladybug.tools/honeybee-primer/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.ladybug.tools/honeybee-primer/components/0_create/recipe_settings.md).
# Recipe Settings
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-36148e56653a973d19fb685bf723ba226018382c%2FRecipe_Settings.png?alt=media)
![](https://3521261292-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-LPHXQ1FZ8W_xSW4Nb61%2Fuploads%2Fgit-blob-01c5658554a21ca1ae117124203e43d93e5d27c2%2FRecipe_Settings.png?alt=media) - [\[source code\]](https://github.com/ladybug-tools/honeybee-grasshopper-core/blob/master/honeybee_grasshopper_core/src//HB%20Recipe%20Settings.py)
Specify settings for the run of a recipe, including the number of workers/CPUs, the project folder, and other settings.
* **folder**
Path to a project folder in which the recipe will be executed. If None, the default project folder for the Recipe will be used.
* **workers**
An integer to set the number of CPUs used in the execution of the recipe. This number should not exceed the number of CPUs on the machine and should be lower if other tasks are running while the simulation is running. If unspecified, it will automatically default to one less than the number of CPUs currently available on the machine. (Default: None)
* **reload\_old**
A boolean to indicate whether existing results for a given model and recipe should be reloaded (if they are found) instead of re-running the entire recipe from the beginning. If False or None, any existing results will be overwritten by the new simulation.
* **debug\_folder**
An optional path to a debug folder. If debug folder is provided, all the steps of the simulation will be executed inside the debug folder which can be used for further inspection.
* **settings**
Recipe settings that can be plugged into any recipe component to specify how the simulation should be run.
